Nestrādā salona ventilātors.
Viensjaanis
Post by Viensjaanis » Thu Jul 05, 2018 8:31 pm
Pēc darba iekāpu mašīnā,ventilātors desmit sekundes pastrādāja un apklusa.Klimatkontrole rāda ka strādā uz pilnu jaudu,bet reāli ir klusums.
Fiksi pārgāju drošekļiem,visi veseli.Aizrakos līdz ventilātoram,piemērot vadus pa taisno viss griežas.
Pamēriju ar testeri strāvu divos resnākajos vados,kas pienāk pie ventilātora,tur 13 volti.Teorētiski būtu jāstrādā,bet...
Man ir 2002 gada 9-3 OG.
Varbūt kādas idejas?Paldies!
Re: Nestrādā salona ventilātors.
Post by Highlander » Thu Jul 05, 2018 8:50 pm
Slinkums jau atkartot, lasi:
Oct 30, 2007 · #1
9-3 and 900NG ACC Code Listings and Diagnostics
Since there are so many posts and questions regarding these fine items, I have transposed the workshop manual for everyone. Funnily it does not list some codes I have seen here.
Please note - there are differences between the 900NG and the 9-3. Key feature - the 900 NG displays the # of faults and you need a scan tool to retreive them. The 9-3 ACC will display the codes themselves.
Enjoy!
1999 – 2002 Saab 9-3 ACC Codes
Calibration:
Automatic ACC control module calibration occurs when the ignition has been turned off after ACC control module replacement or when power supply has been interrupted within 10 minutes of the ignition being turned off. Calibration is required when a stepping motor has been replaced or position has been changed.
To manually recalibrate the ACC control module, start the engine and allow to idle. Simultaneously press the AUTO and OFF buttons. ACC display panel will flash one time, indicating that calibration and self diagnostic test has started. During the calibration “0” will be displayed or any Diagnostic Trouble Codes (DTC’s) that have been detected. Calibration and the self diagnostic test should be completed in about 30 seconds.
Up to 6 DTC’s may be stored at any time. The number stored will be displayed by up to 6 fan speed motor bars. All stored DTC’s are cleared at the start and while the calibration and self diagnostic test are in progress. When completed the number of faults will be displayed on the ACC control module display through the fan speed bar method. The initial code should be displayed first along with the bars.
ACC Scan Gen’l Details
Code Code
01 – B1605 – ACC Module – Internal control module failure
02 - B1350 - Cabin Temp Sensor - Open circuit or short to battery or short to ground
03 - B1340 - Solar Sensor - Open circuit or short to battery or short to ground
04 - B1347 - Mixed-Air Temp Sensor - Open circuit or short to battery or short to ground
06 - B2492 - Mixed-Air Damper Stepping Motor - Open circuit or short to battery or short to ground
07 - B2496 - Mixed-Air Damper Stepping Motor - Jammed Damper
08 - B2495 - Mixed-Air Damper Stepping Motor - Loose Damper
12 - B2400 - Air Distribution Stepping Motor - Open circuit or short to ground
13 - B2406 - Air Distribution Stepping Motor - Jammed Damper
14 - B2405 - Air Distribution Stepping Motor - Loose Damper
20 - B2425 - Blower Motor Control Voltage - Open circuit or short to battery or short to ground
21 - B2410 - Recirculation Damper Motor - Open circuit or short to battery or short to ground
23 - B2945 - Sensor Ground - Open circuit or short to battery
Viensjaanis
Post by Viensjaanis » Fri Jul 06, 2018 12:27 am
Izveicu kalibrāciju,kļūdas nerāda.AC arī dzird ka strādā.Varbut rezistors pie vainas?
Post by Silver » Fri Jul 06, 2018 7:31 am
Nezinu kā 9-3, bet man pie līdzīgiem simtomiem izbeidzās ACC Fan speed controller, kaut kā tā saucās. Paguglē.
Post by Arnijs » Fri Jul 06, 2018 9:04 am
Voltāža nav amperāža. Ja vados ir 13V, tas nenozīmē, ka tur būs arī attiecīgie A. Sāc vien ar regulatoru.
zariene
Post by zariene » Fri Jul 06, 2018 10:05 am
100 punkti, ka rezistors. Man ir gadījies, ka samainu visu, arī pašu pūtēju, bet nestrādā. Beigās secināju, ka štekerī vadiņš bija izkustējies un nebija kontakts. Mierinājums, ka jaunais pūtējs ir klusāks. :roll:
SAAB Griffin 2.3T '93 (200hp)
SAAB 9-5 Aero '06
Viensjaanis
Post by Viensjaanis » Fri Jul 06, 2018 10:28 am
Tātad rezistors būtu jēdzīgākais nākamais solis.
Post by Brand » Fri Jul 06, 2018 1:50 pm
iebliez ar kulaku pa viduskonsoles apakšu. pasažiera puses iekšmala, kur panelis saiet kopā ar tepiķi 8)
9-5 '07 B235R
9-3 '08 Z19DTH
