OG9-3 Durvju un Salona Apgaismojums no 9-5
reinisb
Post by reinisb »
Sveiki,
Iepatikās kā 9-5 izskatās durvju un salona kāju apgaismojums un tapēc nolēmu veltīt divas dienas un uztaisīt tādu priekš mana OG9-3. Tālākais teksts būs angļu valodā, jo dokumentāciju liku saablink forumā. Ceru, ka kādam noderēs.
Hi,
I took 4 stock puddle lamps (4740494) and 2 stock footwell lamps (4740494) from a wrecked 9-5 and installed in my OG9-3.
For each of the 4 puddle lamps, which are located at the bottom of each door, the always-on 12v was taken from a +30 TEL0 connector behind the passenger kick panel. Earth was achieved by connecting to each door's pin switch. Hence, once a door is opened (and the switch makes earth) the respective puddle light turns on, and once the door is closed (no more earth) the light goes out. Simple.
The 2 footwell lights are located at passenger and driver sides under the dash. Power and ground was achieved by tapping in the front roof dome light's three-function switch. Power wires were routed down the right side A-pillar. The 2 footwell lights work in sync with the front and rear dome lights. Again, simple.
Here are a couple of images with brief commentary of the installation process. In addition, there's images and a video of how it looks after the installation. I think that it looks awesome!
Enjoy!
PS Sorry for my English (I'm not a native) and for the poor image and video quality (those were taken with a phone).
http://youtu.be/OoHGkoE6iIA
The parts (it was actually 60m of wire)
New terminals and original black plastic connector
Lamp with the connector
Cutting through to chassis-to-doors rubber hose connector
Rubber hose connector
Wiring through the pins
Puddle light after cutting the hole and putting back the door trim
Wire and connector at a door
Wiring from rear door to chassis
Connecting additional earth wire to the door pin switch
Applying the original plastic terminal cover to the pin switch terminal
Tapping into the front roof dome light for footwell lights
Secure splitter for both footwell lights behind glovebox
Puddle lamp in the front door
Puddle lamp in the rear door
Footwell light in the passenger side
Footwell light in the driver side
Puddle lights
Footwell lights
Puddle lights
Puddle lights
Re:OG9-3 Durvju un Salona Apgaismojums no 9-5
Nu malacis! ;)
zaz
Post by zaz »
Ļoti OK sanāca.
Kā tad beigās tās lampiņas deg, atverot vienas durvis ieslēdzas visas spuldzes, vai tikai tajās durvīs kuras atvērtas?
reinisb
Post by reinisb »
Paldies
Nevienu brīdi nebija runa par to, ka atverot vienas durvis lampiņas ieslēgtos visās. Iedegas tikai tā lampiņa, kuras durvis tiek atvērtas.
Smuki!
Vēlreiz parēcu brīvdienās, ka Mazdai 6 (2003 gada) atvērot vienas durvis lampiņas deg visās un panelī ir vnk simbols, ka ir atvērtas kkādas durvis, precīzas norādes kuras - nav:laugh: :laugh:
Tomēr noslinkoji ielikt arī kontaktus štekeros starp durvīm un virsbūvi:P
A6 Audikā apgaismojums ir arī aizmugurējiem pasažieriem:P:)
Stapr citu neesi domājis kājās ielikt zaļās spuldzes, lai ir vienā tonī ar paneli?:)
P.S. Kas pa izpūtēju? Interesanti skan.
reinisb
Post by reinisb »
KoreFun wrote:Smuki!
1) Jā, man arī vienam draugam ir tāda pati mazda un viņiem ir šitas joks - arī pasmējos]
2) Lieta tāda, ka es nevarēju nekur atrast tāda tipa termināļus (tos metāla savienotājus). Tiesa, uz vikingiem nezvanīju. Bet nu domāju, ka būs OK.
3) Kad man galīgi nebūs ko darīt, tad arī aizmugurē uztaisīšu :)
3) Oi...man viss rajons augšā, kad ieslēdzu mašīnu. Kad biju pie arnija uz apkopi viņš ieminējās, ka vajadzētu sākt krāt izpūtējam un tā arī ir. Vienīgi pašlaik galīgi nav naudas tam. Starpcitu, ir jēga likt to (ja nemaldos) 3" saab sporta izputēju - tādu kā Viggen? Cik vispār maksā jauna izūpētja sistēma? 1000LVL?
A šrotā nemēģināji dabūt tos kontaktus, vai nu arī viena štekera abas daļas..
Ja Tev ir stock un neplāno neko darīt, tad sportiskāks izpūtējs nav vajadzīgs.
reinisb
Post by reinisb »
Pirms biju šrotā pēc lampiņām nemaz nezināju, ka tur būs tādi kontakti. Biju domājis, ka būs tā pat kā aizmugurējām durvīm - vienkārši vadi.
Man ir automāts un, manuprāt, tas pēc definīcijas nozīmē ka neko nopietnu nevaru darīt. Itkā ir kkāds softs uzlikts un aero (mitsubishi) turbīne, kas kopā dod 245bhp, bet citādi neko nedomāju papildus taisīt.
Cik apmēram maksātu standarta visa izpūtēja sistēma?
Hmm, TD04 un 245 hp.. Nice;)
